Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ
7 года 5 мес. назад 7 года 5 мес. назад от Brutto.
Brutto
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63277
«D-1943»
«The Free Energy device was first made in 1943 in Dresden, the project was stopped because there were no possibilities and technologies to complete ... unconfirmed information says that altogether worked for the aircraft named "Glocke" I repeat only the theory, But we are finally finished device with power of 7.4 kW 220/380 V. at the end of the August 2016 we go testing live on this channel. After these period goes and sells equipment to the principle you order and we deliver it. Now in the territory of the European Union. The device delivered to the address, buyer pay 30 days later, with the possibility of return if do not want the device - trial costs nothing.
Guarantees will be, but no need, the appliance components exist in the industry for 50 years so it is unnecessary warranty, the product will work a minimum of 50 years. After the device is switched on, never turn off. The device is used for; all devices on the power 220-380V 50 Hz, maximum 7350 W this means for example electric water heater for the house with central heating cca. 4kW, 2.5kW washing machines and lighting at the same time can be included. all above 7.5 kw unit automatically pauses until the surplus power off. The device does not consume any fuel as such perpetual motion. Price of the final model in sound insulation box will not be higher than € 3,000! More info on; Адрес электронной почты защищен от спам-ботов. Для просмотра адреса в вашем браузере должен быть включен Javascript.»
«...but it will be a smaller model of 1.25kW with a travel bag, I think it will be a very affordable price»
7 года 5 мес. назад
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63362
MC пишет: Бред полный, двигатель ничего не вращает кроме маховика с какими то сферами.
Если ты про Колокол, то там не маховик а статический возбудитель по типу Тестатики.
но например чтобы питать один дом колесо в Тестатике, которая в Австрийской деревне, размеров почти в два этажа.
Второе утилизация идет через систему лейденских банок ну и т.д.
Какая тут система можем только догадываться.
7 года 5 мес. назад
MC
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63366
Rakarskiy пишет:
Не надо гадать, автор пишет что машина не имеет вообще никакого отношения к тестатике.
7 года 5 мес. назад 7 года 5 мес. назад от Rakarskiy.
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63370
Чтобы не отвечать несколько раз в личинке, предлагаю заинтересовавшимся рассмотреть и рассчитать катушку и соединительные провода для системы импульсного взрыва.
На одну катушку у вас должно уйти до 90 м медного провода в диаметре 1,25 мм. при напряжении источника 24В (в реальности 26-27)
в одной системе их три, для разгонной системы не меньше 3 (9 катушек) на 6 N-полюсов ротора, а лучше 15.
так что не дешево только по меди. я имею ввиду мотор.
Схема будет выглядеть так.
Лично мое мнение система генерации Адамса уже не нужна.
7 года 5 мес. назад 7 года 5 мес. назад от yurum.
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63371
Rakarskiy пишет:
Rakarskiy тестатика это вымысел она существует ток в легендах-фантазиях
хорошо об этом на скифе написали да и по ящику показывали
www.skif.biz/index.php?name=Forums&file=...topic&t=68&pagenum=1
ru.wikipedia.org/w/index.php?search=%D1%...4wn1f5abu41zmmmusiwd
эт как капанадзе кино есть а установки нету. муляж
7 года 5 мес. назад
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #63583
как бы таблица. как бы утопия но математика
7 года 5 мес. назад
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #64642
7 года 5 мес. назад
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #64669
Вот именно! Возьми свою платежку за электроэнергию. За месяц вывели среднюю за день, за час, за минуту, за секунду, ну и за импульс. Надеюсь школьной программы хватит.
7 года 5 мес. назад
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #64674
Р = V*A P это что, афаризмы оставь своему жидку учителю физики.
Электрическая мощность в чем измеряем или ты оплачиваешь использованные джоули часы
7 года 5 мес. назад
jay8029
Импульсные моторы, МОТОР-ГЕНЕРАТОРЫ #64676
FMVictor пишет:
Rakarskiy пишет: Р = V*A P это что, афаризмы оставь своему жидку учителю физики.
Р = V*A, Р -это мощность. И чё???
В ваттах, или дж/сек.
Нет, мы платим за джоули или за ват*сек, или Кватт*час. Именно так, и вы также платите. Потому как платим мы не за мощность, а за энергию. А вы что, этого не знали???
Вот и говорю, что уроки физики, а как выяснилось, и арифметики прокурили.
У вас "час" такая плавающая единица.
Кол. сек за час =1 час.
Кол. сек за 3 часа = 1час
Кол. сек за 6 часов=1 час
Кол. сек за 12 часов=1 час
Кол. сек за 24 часа=1 час
Здорово. СЕ очень хотся.
Нифига СЕбе чел платит за ЭнерХию!!! Вотоно че Михалычь,все за квтч а Он за Энерхию....
